nm9stheham
OK, that may help.... if stock flat tops, .100-.110" in the hole (below deck) and open heads and a standard Felpro head gaskets, the static CR would be on down around 8.0:1. Dynamic CR around 6.3..... well below stock DCR. (And some stock replacement types have a shallow dish in them which would lower the numbers even more.) Is there any piston part number in those notes?I just found some notes from when I got this engine.
The guy said it was bored 30 over and had flat top pistons installed.
596 heads
The torque converter is rated 1700.
I will have to figure out the gears, but I would assume stock.
The engine and car did not come together, the stock engine was a 318
Stock-ish TC. May well be a low rear gear. Tnx for the info...helps.
Once those compression readings are in, and we know for sure...... are you open to changing head gaskets and TC? Or even the heads?
