Dartfreak75
Restore it, Dont part it!
Sorry I missed this!Compression tester is the one tool I don't have, but should get.
Oh crap that is not a good cam I thought that was the summit 454 lift cam! To much cam for that setup!!That is a good cam!!
I had headers they did not fit, I didn't want to pay $800 for ones that fit.Some serious mis-matched components, that cam and factory manifolds. And, the factory manifold on the passenger side has a flap that can rust shut, plugging that side of the exhaust.
- Your dots on the timing chain: Is it a 3 key way timing chain (+/- 4* and straight up) ? Did they line up the dot on the key hole of the crank? or the dot by the tooth?
I think that is the cam, I can't find the card, but I had it bookmarked.Oh crap that is not a good cam I thought that was the summit 454 lift cam! To much cam for that setup!!
your doing the right things. I would certainly do a compression test next, but a cam swap may be in your futureI had headers they did not fit, I didn't want to pay $800 for ones that fit.
JB Welded the flap open on the outside lever.
The cam and crank and crank are lined up dot to dot, it is not the adjustable type.
Ok, great. Just make sure the tool you use is known to tell the truth, because part of a cam recommendation will be based on your results. If the tool overstates the facts then you will get a bad recommendation.If changing the cam will fix the problem I am fine with that, it's not a drag car, I just want to drive it.
Everything else will cost more money and work.
I did not choose the cam so I will try to find something better.
After I check the compression.
A question about this, when I have advanced the timing just by hand a small amount, I did get more performance out of the engine at 5-10 mph.You will HAVE to open the distributor and shorten the mechanical advance. That cam will require 18+ initial timing. More likely in the 20-22 range.
Two pieces to advance, initial and mechanical to hit your total number. Initial is more important than total.
You also have no idea were the cam is timed. Lining up the dots is not a good method to install a performance cam. It needs to be degreed to verify install. If it was mine, I'd advance the cam 4 degrees, maybe more.
Not a great cam unless you have more converter with no rear gear.
I am a quite an amateur at this, and at first I did not have the linkage connected after the engine went in.And one final question OP... which may be dumb to ask, but just making sure. When you stomp on the gas, while cruising at, say, 40-45 mph, does the trans downshift from 3rd to 2nd? Just making sure your downshift linkage is in place and setup somewhere close to correct.
While you are about this, it would be good to see/find out what rear gear ratio you have. It will be on a tag under a rear axle pumpkin, and read something like '2.76' or 3.55'. If the tag is gone, then there are a number of videos on YouTube showing how to do it. (The results get interpreted differently for a limited slip versus 'open' (non-limited-slip) rear gear.)
The 'something better' for a cam will depend on several factors, as AJ pointed out. He missed one: how you want to use the car/engine. But I think we can say now that you want a good cruiser/driver, not a drag car.
BTW, do you have any further info on the new torque converter? Is it just s stock replacement tans/TC?
And, if this is a cam issue, and you want to time the existing or new cam (as properly suggested), and which may be good to install advanced a few degrees, then you will need:
- A timing gear set with an settable crank sprocket, like this; see the 3 key slots on the crank sprocket for adjusting cam timing: Mancini Racing Double Roller Timing Set
- And then a degree wheel, which can be bought, or printed and pasted on foam poster board from the following link; the center hole has to be cut as accurately centered as you can if you do the 'paste-on' one here: The Machinery Cleanery Universal Timing Disc, Degree Wheel, Downloadable - Goniometro per Messa in Fase dei Motori a 4 Tempi -
- And a borrowed/bought dial indicator to measure the .050" lift angles of the lifter
I followed break in procedures, I thought this could be an issue and took off the manifold last time, everything looked OK to me, when compared to pictures of other peoples cams I saw that were asking the same question.how long has this motor been assembled and running?? Are ya sure a cam lobe or two isn't flat ?
ok. Just trying to tie it all together.... the "pinging and no power" I meanI followed break in procedures, I thought this could be an issue and took off the manifold last time, everything looked OK to me, when compared to pictures of other peoples cams I saw that were asking the same question.
I don't think I have a photo.
OK, at least that issue is likely out of the equation, as you say. Just needed to be sure. Sounds like this 'no torque' situation is happening in 1st or 2nd gear, so is indeed a real issue.I am a quite an amateur at this, and at first I did not have the linkage connected after the engine went in.
Then I found out what it does and connected it. I don't know if I have it adjusted correctly, I followed the instruction I found online from an old service video.
Mostly my testing has been around the neighborhood at low speeds. I figured that would take the down shifting out of the equation.
You can get get pinging with ANY SCR/DCR. Just advance the timing enough ... Example: I had that high 5's DCR rally engine knock when the distributor got whacked and moved waaay advanced in ignition timing. And I over-advanced the ignition timing on a worn out Vega engine and got it to knock too LOLok. Just trying to tie it all together.... the "pinging and no power" I mean
yeah, I know. But it seems he has moved his distributor in many positions of timing. He's verified the timing chain is on dot to dot. Just look'n for any possibilities...You can get get pinging with ANY SCR/DCR. Just advance the timing enough ... Example: I had that high 5's DCR rally engine knock when the distributor got whacked and moved waaay advanced in ignition timing. And I over-advanced the ignition timing on a worn out Vega engine and got it to knock too LOL
no worries I didn't read the first time past the first couple sentences it's too much sometimes...Post 33 edited
