Dean Scott
New Member
I need a oil pan that will fit a 360 and will be going into a 1970 Demon A body that had a six cylinder in it. Can someone head me in the right direction. Thanks
That's a decent price for everything you need!this should fit it. may want to call and double check though.
Mancini Racing Center Sump Oil Pan Kit
And while you're at it, you may as well get these:
Engine Performance & Vehicle Customizing Products From Hedman | Hedman Performance Group
Doh!those are for a big block. though he was doing a small block swap.
used the transdapt swap mounts on out dart. not a fan of them. prefer the Schumacher ones.
Meant to link these:
Doh!Meant to link these:
They've worked fine for me, but everything is never 100% in all cars. With Schumacher currently unavailable, they're the only game in town that I'm aware of.
Anyone know how much lower that Mancini pan hangs down compared the stock?
They claim it fits LA and Magnum 360's... but they are not the same. What are they putting in the soup to make that work both ways?
LA 360s and Magnums will take the same pan, using the appropriate gasket set for the pan.They claim it fits LA and Magnum 360's... but they are not the same. What are they putting in the soup to make that work both ways?
