360 question
heres the springs they recommend edelbrock 5777 sure seat valve spring heres the specs, Sure Seat Valve Spring; High-Performance Street; Non-Rotator; Seat Pressure 91-100 lbs.; OD 1.5 in.; ID 1.075 in.;
im just going to bite the bullet and put springs in it even though i just bought the 360 i really wanted
Quite too big of a cam for a stock low compression engine unless you want to rev it very hard. It'll just putt around below 3000 or so RPM and at some point start taking off after that. Not for street driving for sure.
Don't forget to change the timing chain while you are in there.
