AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,934
- Reaction score
- 12,284
If the pump is properly indexed and the TC is pushed all the way rearwards, it will stay there and you should have about 3/8 inch (or more) between the TC and the flexplate ears. Oh wait, that would be LA to LA parts.
I see you added some pics to post #1, or at least I didn't see them earlier.I see your TC is far enough back, in fact it looks to be too far.Does the starter pinion engage it fully? The LA ring gear is usually running closer to the front face of the bellhouse.
I can't see that Magnum flexplate working with the LA convertor. As you can see the TC stops when the ring gear hits the tone-ring. Does the TC come all the way in to zero clearance between them? It's kindof hard to judge from the pics. If you have to pull the TC in with the bolts, that would distort the flexplate, and I suppose, balloon it forwards into the engine, again it's hard to see from here.
I think that one or the other is going to have to be changed, and I would ditch the Magnum flexplate, since I can see you are running a regular mechanical-advance distributor.
