Dodge Shart
Active Member
reinstalled everything and still isn't happy.
I will give that a go. If the flex plate is fixed to its spot would it just move the converter forward or with the converter stay further back when pushed in all the way.
Not sure if it helps but I have the same Magnum/904 combo and it does indeed work. Don’t give up.
I mentioned checking crankshaft thrust early on in this thread, but the suggestion was ignored I suppose.
