1974DartSwinger
Hey guys, I'm having a blast with my new ride! Had my '66 Barracuda for almost 3 weeks now and put an easy 700 miles on her! haha, love it!
A little background: from what I know its a stock 360 (1974) block/heads with original '66 Carter #4120 273 hi-po carb and intake. Stock distributor (points), duel 2 1/2 exhaust with turbo mufflers and factory manifolds.
I pulled the carb the other day to give it a clean up and rebuild, checked the floats and sprayed all the passages out. The choke pull off was broke so it got a new one and the linkages are all good from what I can tell. I tried setting the mixture screws with a vacuume gauge hooked to the carb vac line for the choke pull off once the engine was warmed up. At 800rpm I couldn't get the vacuume to change really at all. I cranked the idle up to 1,500 and it was at about 15 psi vac I think. Still couldnt get it to change with the mixture screws. I could hear the RPMs change a tiny bit so set it at the highest revs and called it good. I noticed while driving at a steady speed the engine would surge slightly. You could feel, very slightly, the power come up / down. I re-set the mixture screws back to 2 1/2 turns out and it got a bit better but there is still a slight engine surge while keeping the gas steady.
I'm not really sure what to make of it , what it means carburator wise or if it could be something else like timing which I havent checked yet. It never did this before I redid the carb. I'm thinking about getting a good quality tach for tuning under the hood, maybe that will be better than a vacuume gauge.
On a smilar note, the thought crossed my mind that most likely the jets in this carb are factory 273 jets. It runs great, has gobs of smooth power from idle to about 1/2 throttle but I did notice above 1/2 throttle there is a flat spot where the power seems to drop off or level out. Maybe I need to fine-tune the metering rods or step the main jets up a bit. The primarys and secondarys are opening all the way and the float height and drop is fine.
In the near future I'll be updating to an electronic distributor. Any of them better than others? Just go with Mopar performance or Mancini's ? Trying to fine-tune everything and make this puppy run her best.
