380 crate cam and stall converter
Magnum Engine Swaps
  1. 7dart0
    7dart0 Well-Known Member
    461
    53
    Apr 20, 2012
    peabody,ma
    Local Time:
    6:55 AM
    I'm running the magnum 380 crate cam with hughes heads and 1.7 harland sharp rockers. What's a good converter with that combo? Also have a 904 trans. And 4:10 gears
  2. SplangJ
    SplangJ FABO Gold Member FABO Gold Member
    23
    14
    Jul 13, 2019
    California
    Local Time:
    3:55 AM
    I didn’t know anyone even made 1.7 rockers for Mopar, guess I’m outta the loop. Give all your specs to Frank Lupo’s Dynamic transmissions, they’re very good! I would guess for street and strip around 3000 stall.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • YY1
      YY1 Well-Known Member
      6,499
      2250
      Oct 11, 2011
      FL
      Local Time:
      6:55 AM
      1.7 for Magnum head pedestal rockers which had 1.6 from the factory
      • Like Like x 1
      • Agree Agree x 1
      • rumblefish360
        rumblefish360 So close, yet so far away
        36,899
        8742
        Jun 21, 2005
        New York, on a Island
        Local Time:
        6:55 AM
        Street or strip?
        Car weight?
        Tire size?
        Do you have a dyno sheet?
        These are the questions that will be asked of you for zeroing in on building your converter.
        Your question is very general. If it were I.....
        3500 street strip, 5K strip.
        Huge difference.
        Frank Lupo @ Dynamic
        Lenny @ Ultimate
        And the list goes on and on....
        • Agree Agree x 1
        • 7dart0
          461
          53
          Apr 20, 2012
          peabody,ma
          Local Time:
          6:55 AM
          I race it a dozen times a summer.
          Weighs 3300 with me in it.
          26-8.5 slick
          No dyno sheet but runs 12.4-5@110 in the 1/4 with 1.88 60 foot.
        • ddartdude
          ddartdude Well-Known Member
          584
          199
          Jan 1, 2007
          Port St. Lucie, Florida
          Local Time:
          5:55 AM
          Got a couple of questions. What brand of plugs are you using? What is your timing set at? I have the same engine in my 66 Dart and have no idea where to start. I bought it somewhat assembled.
        • 7dart0
          461
          53
          Apr 20, 2012
          peabody,ma
          Local Time:
          6:55 AM
          I'm using NGK's, and I'm running around 26* initial 36* total all in by 2800rpm. I have my vacuum advance blocked off.
          • Like Like x 1
          • ddartdude
            584
            199
            Jan 1, 2007
            Local Time:
            5:55 AM
            Just getting mine back together. I have my timing set at 10* initial. Not sure of total yet. It's a 4-speed car with I believe 4.10 gears. Gonna be a street car 99.9% of the time.
            • Like Like x 1
            • triumphman
              triumphman FABO Gold Member FABO Gold Member
              149
              22
              Sep 5, 2013
              Oklahoma
              Local Time:
              5:55 AM
              Appears you have plenty to work with.(Information provided above)
              I am running a 408 Magnum with a 2800-3000 stall, also with a 904 & a 3:91. timing @ 24 with 34 total. It has not been on a dyno or at the track.
              DUI ign. Seems fine. Just need to put it on the dyno.
              • Like Like x 1
