383 and 904
ford12989
Active Member
Pennsylvania
Is it possible to bolt a 904 to a 383 or is it not recommended? Not looking to run the car too hard just a Sunday driver. Thanks.
True. You ''could'' use a J.W. bell housing, around $600.'bout 8 years ago I put a 518 behind a 500''RB with their bell. Had to run a 10'' converter as the stock one (12''?) hit inside the bell that is thick. Cut off the smallblock bell and the J.W. bolts to the front pump. It worked but had at least $1000 in it when all done.There maybe other companies out there.
