I'm looking at 2 dusters one has a 400 and the other has a 383 mainly going to be a street machine is one engine better than the other (don't know much about big blocks and nothing about a 400)
Thanks
Thanks
Thanks
Take each one for a drive.Buy the one that runs better.But what I would do is buy the car with the best body and interior.You can do alittle upgrading to the 383 or the 400 and really wake the motor up.
I've had both motors. The 400 is a dog. It was basically a de-tuned motor to keep the government happy.
I had a 1964 Plymouth Sports Fury with a 383 4bbl automatic that ran high 14:00 in the quarter that was completely stock.
Versus a 1972 Dodge Charger with a 400 Magnum automatic that ran 17:00 in the quarter bone stock.
The 400 Magnum has a real crappy intake manifold. It has an internally built in E.G.R. valve that hurts performance. On top of that is the Thermo-Bog carburetor! Never really was too impressed with that carb.
If you can find a rebuildable 60's 383 with small chamber heads I think it would be the way to go. The 400 may have a larger bore but I'd bet on my old 383 every time.
bigger isn't always better, 383
You'll find more parts and better parts available for the 383.
If your reffering to my duster, I will tell you it was stock, "bone stock" with a 2brr., money was tight & i got the Newport for nothing, so i dropped it in, the Newport manifolds wouldn't fit, got a set of HP manifolds on a trade, this was back in 92, the car had lots of power & was fun to drive, This was down in Corpus Christi Tx., so Alt. was on my side seeing i was no more then 50ft. above sea level, i'm sure that helped alot, either way, when it came to the Duster i put together, it had a "STOCK" 400. I have also seen a couple over the years with stock 400 long blocks with exception of a cam (ok stock rotateing assembly/heads) & bolt-ons/gears/stall, they ran surprizeingly good.
Joe, 1st up, I thought there was an issue with the "Quote" in your post. I tried to fix it. Nothing else was modified. Sorry about that.
2nd I wasn't refurin to you or your car in anyway shape or form. Though I certainly understand a tight money issue. Now, IF ya can remember, what did the other lo-comp 400 combo cars ran, I'd like to know. I'll also have to go this route for a while.
Should things go well, perhaps I'll add a hair drier blower to it. First it'll be a set of 4.30's and I'm thinking a 29 inch tire. Future cam unknown at this point. 296/.557 purple? IDK
ehhhh....lots of 400s came with steel cranks. I had one.
