I would not bother using those heads. I would not buy any factory heads for use on a stroker. I would use X or Magnums, ONLY IF I had them àlready.... I wouldn't even consider buying them if I didn't.The intake valves are 1.780 and would like flat tappet. Rpm around 1800 to 5000
Agree.Then you certainly need to watch camshaft size. You will easily over cam that engine. In fact, I'd say the factory 340 cam would be to big. Those heads are going to be a real cork with 318 size intake valves. You now are displacing 390 cubes. That was a Ford big block. Get it? You need more cylinder head.
Oh !!! That's a Big factor to leave outI'm in 4500 altitude
Scour some local yards. I believe the 345 casting is on late 4bbl small blocks. I have run several sets and both machine shops commented on the quality of the castings and exhaust seat. You'll want to run a bowl hog in the intake to open it up a bit.I definitely hear and understand you all that's why I'm here getting your advice. Now dose anyone have a decent set of heads? I can grind my own seats and valves if they need guides i have a guy that can do those. I don't have many mopar guys in my neck of the woods.
Good luck with your build. If your going hyd cam you'll want a set of good lifters, like Howard's. Your 390 will need some "dwell" to properly fill the cylinders. Call Racer Brown and talk shop...Perfect I found a set that were on a motor home I'm getting them cleaned up right now.
No sweat. I'm at 4700' so I get the struggle. Most cam grinders don't speak Mopar fluently.Thank you for taking the time.
That cam is very close to the 440 4bbl. good torque.[/URL]
Basic RPM Range:
1500 to 5000
Valve Lift Intake:
.450
Valve Lift Exhaust:
.465
Duration Intake:
267
Duration Exhaust:
277
Duration at 050 Intake:
213
Duration at 050 Exhaust:
223
Lobe Separation:
112
https://www.forabodiesonly.com/mopar/attachments/154-157-pdf.1714818601/That cam is very close to the 440 4bbl. good torque.
