j par
Will a stock fuel pump provide enough fuel on a 408 stroker to the end of the 1/4 mile?
What horsepower are you designing your motor to make??
holy crap! Almost screwed up my phone was in the garage doing a little home porting and I think I magnetized myself! Lol
horsepower could be the question of the day? !
×2 600 cfm edelbrocks tunnel ram, 596heads (home porting- smoothing exhaust ports/ opening under all seats just a little bit- not getting carried away here I'm a first timer) then back to the shop for valve job-1.60/1.88 . Solid cam (regrind) cam- duration@ .50 - 259/267 lift gross 546/566 lash .026/.028 lob sep. 104/110
Av. 107. 273 rockers. 360 block, scat stroker (cast) crank, scat I-beams, icon forged flat tops - 10.8 : 1 with 70cc heads.
Of course this will be in my 73 duster
gutted
4 speed
355 sure grip
26 in street slicks
hopefully high 12's? ???
Actually I'll start a new thread with this stuffWhat horsepower are you designing your motor to make??
gutted
4 speed
355 sure grip
26 in street slicks
X2 on what Perfacar said. My 408 is a single carb that makes about 440 hp and a stock pump ran out of fuel half way through 2nd gear. Changing a fuel pump is easy though so if you want to try it go for it. Then if it doesn't work you can swap it out.
BTW: I hope your not still running the stock a-body 5/16" fuel line and pickup for 2 600 carbs. I can't imagine they'll do the job
