69B-Cuda
I have a question on piston rings. I have a 73 440 out of a motorhome, stock bore, I honed the cylinders and the ring gap is a bit bigger than specs. I"d like to get the file-to-fit rings. A lot of them I see are 1/16 thick instead of the 5/64. Was there 2 different ring thicknesses from the factory, or can you put the 1/16 rings on pistons that have 5/64? (assuming not ...)
