flathead31coupe
how do I tell witch way a rod cap goes on a 440 I have one that's not marked and I got it turned around...need to know how to tell witch way it goes....
cool thanks.. is 95ft correct for the mains, and 30 ft on the rods...
how about the main caps.....The bearing notch on the cap goes with the bearing notch on the rod. All the others should be in agreement with this to verify.
yes thanks...torque or alignment? notch to notch same as rods. If that's what you're asking.
you are correct 85 mains 45 rods ....If your using aftermarket bolts, refer to the manufactures specs. I'm not a BB Mopar guru...lol. But that rod spec worries me...? I think the rods in the 45/50 range is more in line, and I believe a 85 spec on the mains is sufficient. More input from some other members will help. :thumbup:
