Anyone running one? just curious as to the quality
Im interested in this as well.
I know a few guys using there stuff with no issues. Only thing they do tell me is dont use there pistons. The reason being, 440 source wont tell you who makes them or where they are from. At least that is what I am told. Anyway, lets see who has some info ;)
And upon further research, Eagle kits cost roughly the same as the 440 source kits now and are American made, interesting
So the KB marking on the 440 Source pistons is a cheap version?
I just didn't like the way that hole through the rod throw was not parallel to the throw C/L and didn't go all the way through like the other 3 did.
I'd be building a low compression stroker to run on pump gas anyway, if I decide to go that route. Can't decide if I want to stroke it or not. I need new rods, pistons and crank so by the time I buy all that, it'd cost me about the same to stroke it....
And upon further research, Eagle kits cost roughly the same as the 440 source kits now and are American made, interesting :cheers:
I seen the 440 source rods and they were beautiful top notch quality and im sure the eagle kits are made in china and machined in Tennessee thus made in America they have lots of little tricks.
I had a 440 Source rotating kit. It ws a 520 I got with some other parts on RJ. The pistons are KB hypereutectic. The rods looked like beautoiful parts and has ARP 2000 bolts. The crank was a different story. One rod throw didn't have the hole that runs through the center drilled all the way through and looked to be non-parallel with the rod bearing C/L. Maybe they are supposed to be that way.. The Eagle stuff I bot was better looking to me.
