.497 Purple Cam
GoDartGo
thread killer un-member
Athens Michigan
ADV.288 at.050 244.8 W/ 72* overlap
.497 lift W/ 1.5 rocker ratio
Center line-108
I bought this cam from Rumblefish360 last year.
Found that it's too big for my Magnum heads.
$60 shipped.
PM here
OOO, sorry to read that.
Install @ a 106 centerline, as per MoPar. It has alot of overlap. So this cam idles like a crack head going through withdrawls and is givin an axe to chop through a tree. He can have all the crack he wants if he chops through it in a minute or less. Remember, he's having the withdrawl issues.
Scare the comp with this cam. I've had people drop out at the line with this idle.
that's why I wanted it, but it hits the valve guide bosses on the Magnum heads
with the 1.6 rocker arms. If I don't sell it, some day I will build another small
block with LA heads and this cam will go in it.
Machine the head? Knock the boss down and use positive seals.
I was gonna, but I got to driving it and I'm having a blast the way it is now, and the plans to race kind of fell through.
like I say, if it don't sell.......................Rumblefish, thanks for all the info and help when I bought this cam from you. Your good Mopar!
