4barrell manifold
MILO
Waterford,Pa
I have this manifold What do you think its worth
I don't see an EGR on it so pretty early?
the first year or two of EGR had no external valve. It simply was "jets" in the floor, leaked all the time. Look down into the bores, you will see them. I have a 71, the first year of 340 spread bore, no EGR. I don't know however, if it was federal or CA production
The pictured intake manifold is a 1979 or later version. This style with the relocated thermostat location for the smaller style thermostat was introduced on the 1979 models. The revised thermostat location and bracket mounting bosses are to accommodate the Chrysler C-171 and later Sanden air conditioning compressors.
The first version of the manifold was part number 4100339, casting number 4100340. The manifold was revised a couple of times through the 1980s with casting numbers 4173915 for 1981 - 1984 and 4323352 for 1985 - 1992.
The pictured intake appears to be 4173915.
if it's small port somebody running a 273 or 318 may be interested in it. they're a pretty good manifold.
50~75 is pretty much rate, but shipping would obviously kill any deal.
They made a TQ intake that was 318 port size ???? ??
That's a 74 and up small block intake with exterior mounted EGR valve. The block off plate is plain as day on the driver's side right in the middle. A blind man could see it. As to what port size, measure them and post up what you get.
Thanks Sorry I will back off, on my first post I was just asking what its worth first. I guess I was wrong for asking a question. Will try another Fourm
A good clean intake ready to bolt on is an easy 100.00 in person w/cash.
you can come by my swap stall anytime brother. i'll even provide cold drinks if thats how you roll!
I'll bet you a 100 that if he posts it here for sale for a 100 shipped it will sale in 48 hrs
:lol:
Milo, why don't you put it in a sale thread and sell it. No reason to post it in intake threads as available. That will just get you in trouble.
i don't see where he was actively trying to sell it? it seems he was just asking some questions about what it was to get an idea of what it's worth and the discussion blossomed from there.
reading back, i don't see anybody making mention of trying to buy it?
why would having a discussion about a part be problematic?
:lol:
1st of all, i'm not a sucker. i know that you'd be buying it and that just nets you a free manifold! so, nice try. but i respect the hustle!
i had ostensibly this manifold and a 340 unit, both are very clean at the swap two or three times-- both were under $100 and no takers! and i had coil mounts, t-stat housings and ALL the attaching hardware all cleaned up and ready to go. everything but the gaskets and no dice.
