Hippy1966
New Member
Hoping someone here can help--I have a 2003 Durango with the 5.9 and would like to do a few minor mods thinking Headers TRU Dual Exhaust and a Throttle body upgrade I already have a Cold Air unit and bigger injectors
I know this is a A-Body forum BUTT the Durango guys seem toooo busy with the Hemi's
Thanx
Jim
Thanx
Jim
(the only gains you see are from less air restriction NOT air temp) all fuel injection engines use some sort of mass/density /temp /oxygen sensors and the fuel/timing is based on what the air stream property's are...
your going to have to reprogram the trans pcm also.. IF auto..
