Ges2343
Active Member
This is in my 95 ram.
It’s got 2800 stall converter
Red alto power packs in the direct and forward clutches
Reman pump with stator shaft.
Solid front band
3.8 lever
Fresh rebuild with transgo tfod hd-2 kit installed.
I have a no 3rd gear condition. Clunk seems to be there but not shift. 1-2 shift is there but a bit delayed.
I have been through the valvebody twice now to check my work. I have pulled the direct clutch out and re airchecked found the short seal and replaced with the wide inner piston seal.
Air check on both clutches and they are good. Air checked servos all is well also.
Accum/ line pressure is
1st 64psi
2nd 64psi
3rd command seem to drop a couple psi for a split second then levels back to 64psi
1-2 shift at 15mph
2-3 wants to shift around 35mph
Governor pressure
1st 7psi
2nd 14psi cannot get any higher than 14 psi all the way to 50mph.
I dropped the OD housing tonight and checked the governor seals and the governor valve itself. I don’t see anything out of place. Governor don’t seem to be sticking. What else could cause low governor pressure.
I do not have another VB to check with.
Feels like 3rd is a neutral shift
I do not have the OD and lockup solenoids wires hooked up during testing.
Please help as I am lost
Solid front band
3.8 lever
1st 64psi
2nd 64psi
1-2 shift at 15mph
Governor pressure
1st 7psi
