moper
Not that I've got hundreds under my belt.. but the cast crank stroker cranks, from virtually anyone, are desigend with performacne in mind. It's not like a factory cast crank. With better radii and the usual better balancing, these cranks run surprisingly well. One 416 with a solid roller, and Shady Dell CNC RPMs makes peak hp at 6200 peaking at 540 with the single 4bbl. Those heads flow no more than 280, possibly a hair less, and that's a mild street solid roller. Another 408 with the same CNC Shady Dells, but with some extra hand tweaking by a local pro flow 280 and that one makes peak power at 6500 with a peak of 550. that's a solid flat tappet, and it peaks at 530. That one also uses 175hp NOS kit to run 10.50s in street trim. Both of these are pump fuel. It does come down to cubic cash and honesty. If the car owner is honest with the builder, it isnt really tons more to get big power via more rpm. And th reason you get more power is every firing cylinder is X number of ponies, with so many pnoies in one minute. If you can get more firings per minute, you will have more power. My friend's Stock Eliminator 351 Cleveland used to leave at 6800, and shift at 7200. Even with the Autolite factory 600cfm carb. It wasnt making huge power up there, but it was making good power per power stroke, and had a lot more strokes per second, thus getting more power to the tires (and setting records). I dont use hypers in 4" engines, although I am considering them for a 390 for my truck. It never goes over 4000. But I do use factory rods that have been worked. The rods are the rpm limiter in those cases, and i say dont go past 5500. The decent (Diamond/Ross/Wiseco quality) forged pistons once you get them, are bullet proof to 7K+ wit 4" arms. So really, it comes back to heads. If the heads can move enough air, you'll make big power. Ryan gets huge hp numbers from his 400-450"small blocks as compared to big blocks because of the head choices. Aside from Hemis and Predators, there are no big block heads that can really move enough air for N/A Mopars.
