6.1 no p/steering no a/c pulley
You can do without a pulley in the AC location entirely. You cannot do without a pulley in the PS location. Some guys take apart a PS pump and use it as an idler pulley. Not sure who else has done something in that place.
good luck.
I may have to consider that .. but I have heard of these before ... Anyone have the mopar part # for the car 5.7 delete pulley ????
Depends on how nice you want it to look. I used a PS delete idler from Street & Performance (www.hotrodlane.cc) Beautiful but pricey$ 150 +
x2.... Also less expensive than the Bouchillion piece and much nicer.
HAHAHA ... GOOD TO KNOW.. LOOKS LIKE ILL HAVE TO GO THIS WAY AS WELL!!
I looked at your car NICE!!!!!!
I see your using an indy intake ..
AND ISSUES?
Here is everything that I ordered for the front of mine. This covers the idlers, tensioner and bolts.
04627851AA is the grooved idler that is required for the PS delete. This will mount to 04593918AA.
BRACKET. Idler Pulley. 04593918AA $46.85
TENSIONER. Belt. 04861660AA $51.17
PULLEY. Idler. 04891720AA $18.63
PULLEY. Idler. 04627851AA $16.47
1 - BOLT. Mounting. Hex Flange Head. M10X1.50X55.00. 06104221AA $3.51
3 - BOLT. Mounting. Hex Flange Head. M10X1.50X130.00. 06104230AA $2.70
2 - SCREW. Hex Flange Head. M8x1.25x34. 06509487AA $2.50
3 - BOLT, SCREW. Mounting, Tension Bracket Assembly To Timing Cover Front, Tensioner To Bracket. Hex Flange Head, Hex Head. M8x1.25x30, M8X1.25X30.0, M8X1.25X30.00. 06104025AA $4.59
Got everything from www.factorychryslerparts.com, but the dealer would have everything as well.
There is another possible part number for the PS delete idler (4593985AA), but from what I can tell both are the same part.
Total was $181.63 with shipping and that included the tensioner.
That's a great option... the mopar PS delete part is what im after .. It says 5.7 ..
Im running 6.1 .. Are you running 6.1?
I'm running a 6.4, but it shouldn't matter. All of those pieces should be interchangeable.
I'm assuming you only need 1, 5, 6 and 7 to get the job done the other pieces would appear to be the same on all engines?
It all makes sense now, the tensioner and idler are the same across the board, the PS delete bracket and pully is used on the new models because they now run electric power steering. Good old mother Mopar to the rescue, they obviously couldn't think of a better way to do away with the power steering pump either.
if anyone knows what year these are for would help make parts easier to access .. as we all know a lot of parts guys need . year , make , model , blablaba .. someone else besides mopar has this I'll bet.
Bracket fits the following models:
CHRYSLER 300 AWD, 5.7L V8 HEMI MDS VCT, 5-Speed Auto W5A580 C 2011
CHRYSLER 300 AWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 C 2012, 2013
CHRYSLER 300 AWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 C LUXURY SERIES 2013
CHRYSLER 300 AWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 C VARVATOS 2013
CHRYSLER 300 AWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 S 2012, 2013
CHRYSLER 300 AWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 S EXECUTIVE SERIES 2012
CHRYSLER 300 RWD STR8, 6.4L V8 SRT HEMI MDS, 5-Speed Auto W5A580 2012, 2013
CHRYSLER 300 RWD STR8, 6.4L V8 SRT HEMI MDS, 5-Speed Auto W5A580 CORE 2013
CHRYSLER 300 RWD, 5.7L V8 HEMI MDS VCT, 5-Speed Auto W5A580 C 2011
CHRYSLER 300 RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 C 2012, 2013
CHRYSLER 300 RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 C LUXURY SERIES 2013
CHRYSLER 300 RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 C VARVATOS 2013
CHRYSLER 300 RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 S 2012, 2013
CHRYSLER 300 RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 S EXECUTIVE SERIES 2012
DODGE CHALLENGER 5.7L HEMI VCT, 6-Speed Manual TREMEC R/T 2011
DODGE CHALLENGER 5.7L V8 HEMI MDS VCT, 5-Speed Auto W5A580 R/T 2011
DODGE CHALLENGER 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 R/T 2012, 2013
DODGE CHALLENGER 5.7L V8 HEMI VVT, 6-Speed Manual TREMEC R/T 2012, 2013
DODGE CHALLENGER STR8, 6.4L SRT HEMI SMPI V8, 5-Speed Auto W5A580 2011
DODGE CHALLENGER STR8, 6.4L SRT HEMI V8, 6-Speed Manual TREMEC 2011
DODGE CHALLENGER STR8, 6.4L V8 SRT HEMI MDS, 5-Speed Auto W5A580 2012, 2013
DODGE CHALLENGER STR8, 6.4L V8 SRT HEMI MDS, 5-Speed Auto W5A580 CORE 2013
DODGE CHALLENGER STR8, 6.4L V8 SRT HEMI, 6-Speed Manual TREMEC 2012, 2013
DODGE CHALLENGER STR8, 6.4L V8 SRT HEMI, 6-Speed Manual TREMEC CORE 2013
DODGE CHARGER AWD, 5.7L V8 HEMI MDS VCT, 5-Speed Auto W5A580 R/T 2011
DODGE CHARGER AWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 R/T 2012, 2013
DODGE CHARGER RWD STR8, 6.4L V8 SRT HEMI MDS, 5-Speed Auto W5A580 2012, 2013
DODGE CHARGER RWD STR8, 6.4L V8 SRT HEMI MDS, 5-Speed Auto W5A580 SUPERBEE 2012, 2013
DODGE CHARGER RWD, 5.7L V8 HEMI MDS VCT, 5-Speed Auto W5A580 POLICE 2011
DODGE CHARGER RWD, 5.7L V8 HEMI MDS VCT, 5-Speed Auto W5A580 RT 2011
DODGE CHARGER RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 POLICE 2012, 2013
DODGE CHARGER RWD, 5.7L V8 HEMI MDS VVT, 5-Speed Auto W5A580 R/T 2012, 2013
It's all on the factory parts website linked above, the penny just dropped regards the electric power steering setup on the new models.
Nice thanks to all . im going to assume it can be used on a 6.1 since no srt8 models with the 6.1 had electric p/steering ... wowowowo hoohohoho
