6.4 hemi installation from the bottom.
67Baccaruda
Scotia, NY
I'm installing a 6.4, TTI headers, and RMS suspension in my 69 Barracuda. I was hoping to drop the car over the suspension with engine (headers installed), and trans. I have one of the USCT k frame carts. The steering will be out. Does anyone have any experience with this? Thanks in advance...
I have done this with gen 3 in an A Body. Absolutely the way to go. Good luck with your build. I should add, when taking out the 318, we dropped it all out the bottom. With a lift it's easy peasy. Even before I had a lift, I started doing it that way on freshly painted cars.
I did mine with a chain fall, but I've seen some here do it with a cherry picker but to me it seems the legs may get in the way? IDK
Thanks Guys feel a bunch better. I have a lift and the USCT cart. I'm sure I will need to take the engine and trans in and out multiple times while I figure out tunnel and firewall mods.
Thats how i did it on my car
Only jackstands, engine lift, and some chain and angle brackets....i picked car up from 2 of k frame bolts....got a 45deg angle bracket from home depot to hook up chain to car and sent it....
Ive lifted up a few cars like this so far
Just built this dolly for about $50. Doesn’t help with lifting the car but certainly will work for rolling the combination underneath. 1x2” tubbing and some steel swivel casters n a harbour freight dolly/block under the trans. HDK k member…
I just took it apart this way really slick. The new setup will no doubt need to go in and out a few times before everything is all set...
I hope you have a Roll Bar in that thing so you don't kill yourself!
TF360 Funny, I've had people ask me why I'm not putting a Hellcat motor in it. A 3000lb car with 500 hp is going to certainly challenge my driving skills.
