6.4 throttle cable route
MoparOrNokar
HammerTime
Flint, Michigan
Im looking for pictures of how you ran throttle cable with a stock 6.4 intake. Im not sure how to make the curve to the throttle body
Are you going with an LS tb or one by BBK? Either way, the cable is flexible to turn in any direction. Not sure what your concern is.
A couple of pics on my 6.1. Not sure if this helps or not. I used a 36" Lokar cable p/n TC-1000HT36
Jim
This was discussed a while back when I was testing the hemi I built at pace, prior to my position with blueprint. The bbk TB has the throttle hammer on the opposite side of the pic above. You can route the cable under the intake, and make a tab that mounts to the bolt intended for a heater hose on the timing cover. The throttle hammer actually wraps down, opposed to back...so it works great. Let me see if I can dig the thread up.
I believe that was a factory throttle cable from a Dakota with a 318
