hi everyone working on another project with my 74 /6 duster and i need to pull consistent amps from my battery (about 8-15) .... alternator new reman with good output (13.5-14.5v), replaced crappy connectors on alternator, battery fresh, ground and pos cable clean and large 2 gauge....... i get good amp output until i have my lights, stereo,ect i know this is due to aged wires bad connectors ect,ect..
my question::: can i take a charge wire from the alternator and wire to the battery as well as the rest of the system to bypass the crappy connections and put it wear i need it?
i know its kinda fixing the wrong problem but full harness time will come later a big thank you in advance everyone
amp meter bypassed, light switch new, dimmer switch and headlights new, all other lights led, wires from starter to relay and relay to battery new, alt belt new and tension set
