60's on a smallbolt rallye wheel?
245/60R14 on a 14x5.5 rim......Yes, done it many times with no issues :glasses7:
My Dad has been running 15x5.5 Rallye Wheels with 235-60s up front and 275-60 out back on his Charger for the last 20 plus years with no problems at all
No uneven wear or anything
When I got my 73 340 Duster with its factory Rallye Wheels on it it had 245-60-14s out back and 195-60-14 up front
thanks for the input - had done it for many years on my bbp 14's.... wasn't sure about the spb being slightly narrower.... Now as long as the fit under the rear of Jake's 65 B'cuda, we'll be good......
My Barracuda had 215/70B14's up front, and Pro-Trac 275/60B14's in the back when I bought it. Those rears were tight on the rally rims!!
Should work on a 5.5" rim, although marginal. If original rallye's, make sure they're not 4.5" width.
I've got 235/60r14 on the rear no problem. 245 's would have fit with about 1/2 clearance
I know it's ancient history, but when I put L60x14's on my '72 Duster, the shop I got my tires from, would not mount them on anything under 7"
