63 Dodge Dart, now let me see;)
They both go to power the ignition. One is for the IGN start and the other is for the IGN run position. Right to the ballast unit Then on yours with my HEI to the positive side of the coil along with the red wire from the 4 pin ecu. If you plan on using a ballast resistor jump it to get a full 12VDC.
With your custom HEI wire your IGN 1 and IGN 2 together at the switch , ignore the ground lug on the switch .
As for tires a 225/60R15 for the front and a 255/60R15 will work without clearance problems, the 255/60R15 with 3.55 rear gears will run 3150 at 71.38 mph .
Now that the driveshaft is out of the way, played with the shifter, IT'S OH SOOOO NICE!! I was going to go look at tires, but got distracted by other things. Still have wiring to contend with, but making progress. I have a few days before leaving for Philly again:(
going to sit back now, drink my coffee and ponder :lol:
how long is the slip yoke on the driveshaft? i ask as including the bit hidden by the dust boot (part of the rear seal) that seems an awfully long amount 'out' of the bushing in the tail housing. :eek: hopefully the yoke is one of those very long ones. :thumbsup:
neil.
neil.
I own Glen GGs66GT a debt of gratitude :thankyou: :thankyou: :thankyou: :thankyou: :thankyou: :thankyou: for helping me figure out the tire combinations, . It's the 355 gearing for me which complicated things, for me anyway, so instead of it being a 2.47 the rear tire size went the opposite direction. The wheels will be coming back off as there's more to do. I've very pleased with the tires!!
dne';)
Thanks for the shout out .
Looking good and they clear all around.
Good thing you mini tubed and relocated the springs. Although not necessary for this application. But it gives the option of wider tires with wheels with different backspacing.
Hi my dears~ now the fenders are hopefully permanently bolted on. Wiring mess still going on. I guess if I had a question, and I do, if I wanted to run a fresh air inlet hose to the air cleaner~ Would that be advisable? There already is a large hole to the drivers side of the radiator support. With the battery relocated, don't think it would look weird? Then finding a hose might be a quest!
Don't forget to leave room for a coolant overflow reservoir. It looks like it should go on the driver's side too.
Just a little help here, mainly ign1 and ign2 and does it still need to be grounded. Batt, ACC and ST are easy.
THanks;)
I'd refer to the service manual wiring schematic for your '63 model, with a stick shift. Make sure the ignition switch is appropriate too. Using the key, test the continuity of the different switch positions using two tabs on the switch, then you can tell how they are connected inside. If there is an external tab on the switch, that might be for a safety function, like seatbelts, in later models and maybe not needed here.
Thanks Ray~ that looks interesting and "flexible"!
and thank you too Richard !!
You guys Rock!!!
and a couple pictures for today's entertainment :lol:
just piddlin stuff today~ hope to start the S6 tomorrow, not to drive it, but see how the transmission does and diff. I hope it's all ok :steering:
Obviously wrapped the exhaust just past the slave cylinder~ just wanted to help it survive;)
just a bonus pic :lol:
I wrapped it wet, puling it tightly, the set it out in the sun to dry;)
That's neat Neil! I was just wanting something to make that tight turn coming off the inlet~ I still haven't measured that opening off the air cleaner! lol Oh, I know what I was, I couldn't find a tape measure
3.5" opening and about 19" to the radiator support hole.
see if these work~
When I had put the new drums on, they were quite tight even though the adjusters are completely screwed as short as they'll go.
see if these work~
That is one of the best sounding slants i have ever heard.... it's almost annoying how good your work is :)
BTW.. is that a later hydraulic cam motor? or just lashed properly?
You don't know how good that makes me feel from you comment;) It's a solid lifter engine. 9:1 compression, roll master timing chain, Super six intake, electronic engine by Ray Halifaxhops, reground cam.
