They both go to power the ignition. One is for the IGN start and the other is for the IGN run position. Right to the ballast unit Then on yours with my HEI to the positive side of the coil along with the red wire from the 4 pin ecu. If you plan on using a ballast resistor jump it to get a full 12VDC.
