63 valiant wagon
66 coronet
liberty sc
At my cousins house right now, he has a 63 valiant wagon with a built 360. He wants to upgrade his brakes already has an a body 8 3/4 read fited with 10" drums and wants to fit disc brakes to the front. He has a nice set of wheels and tires so wants to keep the small bolt pattern. cab this be done? anyone tried this?
Yes it can be done as long as he has 14" wheels.
He could use the Kelsey-Hayes disc brakes from a ' 65 to '72 A-body .
There's also the Scarebird kits
Contact this guy and get one of his complete set ups. I've bought a few of them from him. Freshly rebuilt, ready to bolt on from ball joint to ball joint. They are worth the money and he's good to deal with.
http://www.forabodiesonly.com/mopar/showthread.php?t=285395
Then get a hold of the Ram Man for a dual reservoir master cylinder, he has them in manual or power. He's very helpful and will walk you through what you will need to get it working.
7200 Winters St
Fort Worth, TX 76120
Telephone: 817.691.5996
http://www.theramman.com/
Then when you figure out what master cylinder, and prop valve combo you are going to use, get a set of lines from Fine Lines:
http://www.finelinesinc.com/
You may as well get a dual cylinder master cylinder and plumb up the lines. If you blow a brake line with the single reservoir master cylinder, you loose all of the brakes instead of just one set with the dual reservoir cylinder.
thanks for the responses, I'm a member on here, trying to get him joined up. He has the 63 valiant wagon with the 360 and a 62 sport fury with a 413, he had never heard of the site.
My dad special ordered a 62 Sport Fury convertible with a 361 back in the day. Then after he got his, they offered the 413.... :banghead:
never heard of this site, ????? must be from Northern S>C> !!!! LOL he gotta join this bunch!
I reading your original post, it said keep the SBP wheels. going to the 73-up mopar a body disc set up, and someone correct me if wrong, that will give him BBP AND the 8 3/4 A body rear, it could have come with either sbp or bbp axles??????? someone can chime in that knows on the rear .............
