64 225 /6 Pulley Crank Bolt What Size?
You don't really have to have one in it unless it is just something you wanna do. Most of them came without one. The balancer is held on by friction. It seems as though the assembler on the line would drive the balancer on with a bolt then take it back out and use it on the next one and so on. Only occasionally would they leave it in their.
By the way, if you really what one, here is what you need.
T
he crankshaft vibration dampener bolt is 3/4"-16 UNF, 2.3 inches long, with a 1.5 inches minimum length threaded area.
You will also need a thick washer, the washer is 1-15/16" x 1/4".
