64- 66 Barracuda trunk lid help!!!
scottylack
NEW JERSEY
I have two trunk kids. One is off a 64 and has the welded on prop rid suppport. The other seems identical, was on my 65 when I got it. Does not have a prop rod support and a slightly different pattern underneath...
What could the second one be without the prop rid? Did they use another type if prop support in 66 ???? Help!
I think i read here some where they [mom mopar] changed the prop rod style and attaching hardware late 64 early 65. I took photos of my 66 [sorry for multiple shots it's a little tight in the shop with the door closed].
There has been several threads about this same subject so you might want to run a search on the early A-body section or the parts wanted section.
