Apr 17, 2011 #1 65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 14,643 Reaction score 5,590 Location Strasburg, VA I think that the rear wheel well trim is the same for a 65 and 66 Barracuda. I've been told that the fronts are different. Does anyone know for sure?
Apr 17, 2011 #2 Blownfish Well-Known Member Joined May 26, 2009 Messages 1,044 Reaction score 32 Location St.Louis The 64 and 65 are the same, but I believe the 66 has a different shape to it and the rocker molding cut out is larger than the 64 and 65
Apr 18, 2011 #3 R Rick@Laysons FABO Vendor FABO Vendor Joined Apr 25, 2005 Messages 2,444 Reaction score 3,433 Location Lakewood, WA Blownfish is correct. The notches for the rocker trim on the '66 are bigger than on the '64-'65's. Also, the front moldings on the '66 are about 4" longer on the rocker end than the '64-'65's, and the rear trim on the '66's are about two inches longer than the '64-'65's.
