65 dart /6 to SB
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
65 Dart: right now the old slant and tranny is out. ( took 2 weeks to get /6 apart and 3 lb coffee can full of sludge!). never swapped cable shift shifter to make work with later trans. i got 2 /s dusters to fulfill my s/ cravings.
my thinkin: havn't found any runnin slants for free.i can find running 318 or 360 with trans and probably good rad for not much more than price of good /6. i never had much luck with 7 1/4. rad i have for /6 is questionable. who knows about rear end. i have new offenhauser dual 1bbl intake i wanted to use on dart and super six set upalso, these i could sell and use toward SB stuff. my question is what can i do to use the original floor shift with newer trans.??
/6 guys can scold be, i deserve it! LOL
You should be able to sell either of these pretty quick
I will be using a later 904 in my 65 GT 'vert with original floor shifter. To do that I bought the shifter conversion kit from Imperial Services. The kit includes the special cable & bracket and some kind of part that is installed in the valve body. When I had my transmission built by Proformance Transmissions they added the part to the valve body. Hope this helps.
my question is can the 65 dart original console cable shifter made to be used with a later trans???
Yes - that is what the conversion kit from Imperial ?Services does - let you use your original 65 console shifter with a 66 and later transmission. The park cable part of your original shifter is not used.
