flathead31coupe
i got my lower ball joints the other day, mine are straight, and the new ones, part #sk781 have a bend in them...will the work?
i found out they are the wrong ones....I “think” the disc ones have the bend in Them
Drill them SLOW and lubed....they will eat a bit otherwise, very small area the bit catches on and it gets hot.The drum and disc brake lower ball joints should look the same, except the mounting holes are a different diameter. The drum version has 1/2" holes, and the disc brake ones are 9/16". You can actually drill out the drum ones to work on a disc brake application.
