65 Dart GT Revisited
Discussion in 'Members Restorations' started by Old Dart 66, Nov 8, 2017.
  1. 65dartcharger
    65dartcharger FABO Gold Member FABO Gold Member
    6,093
    584
    Dec 9, 2006
    Tavelsjo, Sweden
    Local Time:
    2:04 PM
    Great work Jerry!
  2. 66Dartdriver
    66Dartdriver Well-Known Member
    340
    84
    May 22, 2010
    Erie Pa.
    View My Photos
    Local Time:
    7:04 AM
    looking great! that is a lot of work and is going to be one very nice car when done! love the 65's and great to see anther one being cared for. Mine is also a factory slant with air...well it was a slant lol.
  3. Old Dart 66
    Old Dart 66 FABO Gold Member FABO Gold Member
    383
    83
    Dec 8, 2014
    Iowa
    Local Time:
    7:04 AM
    Hey 65Dd, Yes, it was a /6, but will be a 273 HiPo with 4bbl, 904, SG 3.23. Lots of work, but the hard, dirty work is coming to an end....the rust patches and the rubber undercoat stripping. Now the paint and assembly. Much cleaner and more fun....but its all part of it. Had a 65 Dart Charger back in 1971/72, and I have always wanted another, so a labor of loving this car. Thanks greatly for the comments. Appreciated. Old Dart 66.
    • Like Like x 2
    • Old Dart 66
      383
      83
      Dec 8, 2014
      Iowa
      Local Time:
      7:04 AM
      Just another update on the 65 Dart
    • Old Dart 66
      383
      83
      Dec 8, 2014
      Iowa
      Local Time:
      7:04 AM
      Thought I would update the slow progress on the 65 Dart Revisited. As you know, I am cloning the 65 Dart Charger, and with that, the cars "Gotta Have The Notch" I would like to thank 65 Dartman for his input on how to make the notch using a scrap 65 Dart front valance. It is actually quite easy if you have a welder. So here are some photos. What you do is cut the bumper bracket opening out of the front valance, and you will find that the narrow end of the opening is the end that you want. However, it will be too wide, and it will have to be cut down. While cutting the opening out of the valance, leave enough metal in order to have enough to work with. While shortening the bumper bracket opening to the 6-1/8" opening measurement on the lower part of the resonator notch, leave the radius on either end, and set it up to cut it in the middle....then overlap the two pieces to where you have the 6-1/8" measurement on the lower end of the notch. When you are set up on the correct width, scribe one piece or the other for your final cut, then butt the two pieces together, and weld away. After you have your notch patch complete, set it up on your lower rear valance, scribe your cut with an awl, cut out the portion required, and weld in the notch. The beginning of the notch is at 6-1/4" from the inside bottom lip of the rear of the driver side fender where it meets the rear valance. The height of the finished notch is roughly 1-5/8", but leave plenty of material at the bottom since you can cut the remaining material away after the notch is installed. I got the measurements from a true to life 65 Dart Charger where his valance ended, at the bottom without a reinforcement bend, whereas, my 65 Dart had a reinforcement bend at the bottom of the valance. Do not know if this is standard or not, but, as I commented, leave plenty of material all the way around to fit and cut after you remove the part of the rear valance on your car to fit the notch. Thanks. I hopes this helps someone as it took me some time to find the dimensions. Not too many 65 Dodge Dart Chargers around. Photos are listed separately as I lost them in this post, and do not know where they went. Just another note....cut the material in the middle because if you cut it at the corner, you will lose the radius on the part. That is what I did the first time, and I had to do it over again. If anyone has any questions, PM me at Old Dart 66
      • Like Like x 2
      • Old Dart 66
        383
        83
        Dec 8, 2014
        Iowa
        Local Time:
        7:04 AM
        Here are a few photos of the 65 Dart Notch process fabricated from a 65 Dart front Valance. Thanks
        • Like Like x 3
        • Old Dart 66
          383
          83
          Dec 8, 2014
          Iowa
          Local Time:
          7:04 AM
          A few more photos to finish the sequence. A bit rough on the filler, but right now, the entire car is still a bit rough. Have to make it worse before it gets better. We are limited to ten photos per post...apparently. Thank you again to 65 Dartman for the tip on where to start. Thanks. Old Dart 66
          • Like Like x 3
          • 65 Dartman
            65 Dartman FABO Gold Member FABO Gold Member
            8,901
            1161
            Sep 24, 2006
            Strasburg, VA
            Local Time:
            8:04 AM
            Looking good! Happy to help out where I can!
          • Old Dart 66
            383
            83
            Dec 8, 2014
            Iowa
            Local Time:
            7:04 AM
            Just received my dash bezels back from GCartrim. Glenn did a great job. Here are some photos
            • Like Like x 3
            • txas2step
              txas2step FABO Gold Member FABO Gold Member
              76
              41
              Feb 16, 2012
              houston
              Local Time:
              7:04 AM
              • Like Like x 2
              • 65dartcharger
                6,093
                584
                Dec 9, 2006
                Tavelsjo, Sweden
                Local Time:
                2:04 PM
                How's everything going Jerry? Any progress? Love your build!
              • Old Dart 66
                383
                83
                Dec 8, 2014
                Iowa
                Local Time:
                7:04 AM
                Hello Ulf, To be honest, no progress recently. This Spring has brought over 12 inches of rain to NW Iowa, which means mow, mow, and then mow some more. Along with that, we garden about a half acre. Beyond that, I have been busy getting the parts off of the Valiant. Hope to be in paint, and clear, on the Dart Charger clone by mid-July with it being on the road by October 1st. Schedules and the best made plans are meant to be broken....I guess. Thanks for the inquiry. Jerry
                • Like Like x 1
                • Old Dart 66
                  383
                  83
                  Dec 8, 2014
                  Iowa
                  Local Time:
                  7:04 AM
                  Members, Thought I would update the 65 Dart with no real progress as I have purchased a 65 Valiant Signet to part out. I needed some parts out of it for my 65 Dart Build. Anyway, I got my 65 Dart bumpers back from Sx. City Plating, and I thought I would share a few photos. Doug Boddy and his crew at Sx. City plating, in South Sx. City, Nebraska did a great job. Thought I would give them a shout for a job well done. Currently, they are on the bed, but will look better on the car. Good they are in the spare bedroom. Old Dart 66
                  • Like Like x 3
                  • 65dartcharger
                    6,093
                    584
                    Dec 9, 2006
                    Tavelsjo, Sweden
                    Local Time:
                    2:04 PM
                    Glad to see you got them. All of a sudden they will be on your car!
                  • Old Dart 66
                    383
                    83
                    Dec 8, 2014
                    Iowa
                    Local Time:
                    7:04 AM
                    Thanks for the encouragement Ulf. So much else to get done, but I guess that most retired people run into that. My plan is, still, paint by the middle of July, with final assembly by the middle of September or October. Test drive, hopefully, yet this year before another winter season. Thanks. Old Dart 66
                    • Like Like x 1
