66-67 273 Cylinder Head Part Number and Identification?
Bossanova5
Los Angeles
The Machinist ruined my heads and I'm trying to find a different set from a 66-67 273
The part number I found in the 66 Factory Parts Catalog is # 2536-176
The casting number on my 67 273 heads are # 2658920-5
I have a gentleman on here who might have a set of heads.
What is the best way to identify the correct heads using the numbers cast into the heads?
Thank you
Bring an intake manifold bolt too
If it's a set of 65 and earlier the 66 67 intake bolts will not fit
What size are the bolts for the intake manifold for a 66-67?
He installed too large of a hardened exhaust valve seats. The new machinist believes the heads will eventually leak (Coolant into the combustion chamber) from all the material removed and the pressure exerted to install the hardened seats. He is going to pressure test them, but he still recommends I get different heads and start over. The first machine shop also installed the wrong valve springs, he put hydraulic valve lifters springs in instead of solid lifter springs. The worst machine shop nightmare........
The 273 heads have a very small chamber so unless the pistons are changed the compression ratio will be very low
The flat top 273 piston only gets 8.8 iirc and the domed gets 10.5 iirc
The first machine shop also installed the wrong valve springs, he put hydraulic valve lifters springs in instead of solid lifter springs?
Is This really a Thing? I did a 273 with a Solid Lifter but I used Springs from a 340...
I'm pretty sure that 340's are hydraulic valve lifter springs instead of solid lifter springs.
So, is there a mismatch there?
Aside from whatever other issues might be present….
As far as the ex seats go…….if the heads pressure test good, I think they’d be fine.
As for the springs, they don’t know what the cam is.
They either have adequate force for the task at hand or they don’t……simple as that.
If you're using the '64-6 LH exhaust manifold, using a later "smog" head would require extra clearance at the left rear (#7) exhaust port to keep from breaking the manifold. Best done by a thicker exhaust manifold gasket rather than grinding on the head. Best just to get the correct head.
I believe any of the 66 to 69 year heads will perfectly fit
the exhaust manifold. The mid 70s to 80s would need the
thicker exhaust gasket.
Yup, up to 1974 when they changed to the casting with the A.I.R. provision. The open chamber heads starting in 1968 will reduce the compression ratio a bit though. '66 and '67 920 castings were closed chamber.
There is only 3 CCs difference between the two part
number heads and sometimes different castings CC
a couple CC different than another pair the same number.
In our testing at low 300 to 400 lift the 675 flowed better.
Plus, I prefer the open chamber heads myself as they seem
to have less detonation and better tolerance for bad gas issues.
Just my .02 = For Free
It's not that much...a little off the head...a little off the manifold...you're good.
I believe only a problem IF you are using a 70s something up
Smog head and not any of the early heads.
920's Shipping would probably be $50-75 each now days.
