This is my first try, got bored I guess. Kurt and a host of others have been a great source of knowledge and encouragement. I'm pretty happy the way it's turning out. Hope to have it on the road soon!
Jim
Jim I don't think it is grounded hmmm there is a rubber sleeve that goes in the bracket that holds the column and the dash up. The only place I do think it is grounded is the steering shaft to the gearbox for sure. View attachment !!!!!stering column DSCF2039.jpg
it looks like either this is the ground or there is a ground wire in the harness to the turn signal switch .. I'd have to look to make sure. View attachment !!!!!shaft.jpg
it yeah it does look GOOD!
if you don't have the insulator tube then a 26" bicycle inner tube fits
good (not the 10 speed the regular bike)
in the blowup you can see the rubber isolator that goes in the clamped section
