flathead31coupe
i momentarily grounded the sending unit to ground, dash gauge went to full. installed the new sending unit, gauge moves from below empty to just under empty.. pulled the sending unit, had my brother watch the gas gauge, as i went through the range from empty to half to full, seems to work, ? is i have been guessing on the gas level in the tank, i put 5 gal in the tank when i put in the new sending unit, was thinking it should read more than empty...does the tank hold 5gal when empty...putting in more gas today and re check...
