66 Dart Power Steering question
rod7515
Red Lion PA
My 66 Dart has manual steering in it now. I have purchased a new Power steering box, Pump and bracket kit as well as a lower pulley. Should be everything I need to do that part of the conversion. I know i will need to change the steering shaft and coupling to make things work. I have what I think is a PS shaft and coupling but was wondering if anyone knows what the length of the correct shaft for PS is? Also where can I buy the rebuild kit with new rubber gasket for the coupling? Appreciate any information you may have.
Thanks Rod
You will need to buy a used '66 PS column. Couplers are not available complete but kits are available to rebuild it.
