[WANTED] 67-69 A-Body 383 K-Frame Wanted
jimharvard
JimHarvard
Pittsburgh, Pennsylvania
Looking for a 67-69 Big Block K-Frame for a 440 installation in a 69 Barracuda. I'm rebuilding a 69 M-Code fastback so if you have an original M-Code 440 K-Frame and motor mounts, i would pay serious money for that package.
send me a message here on FABO...
jimharvard
jim coster
pittsburgh, pa
I do have a bb k frame. It is not original, rather a small block converted to big block. Send a conversation with a cell number and I can send pics/price.
jimharvard
jim coster
pittsburgh, pa
Here are some pics of the left side motor mount from my M-Code GTS in 1985. Sorry for the fuzzy pics but gives an idea of how they did these mounts if yours are missing. Factory used C-body mounts and welded a piece of angle iron on and drilled/tapped a couple 3/8 16 holes in the oil pump bosses. If you cant find original mount, make your own. The passenger side mount is the same in all big block A bodies. Send us some pics of your Barracuda
View attachment 1714961193 View attachment 1714961192
hi timsgt...
thank you for the pics of the 440 motor mounts and the information.. that is very helpful!!
i know there are a lot of combinations for doing a 440 in a 69 cuda but i'd like to stay as close to OEM as possible. here's some pics of the car as it is right now. and thanks again... i'll probably have some more questions for you as i go along if you don't mind.
take care
jim coster
1108 Peachtree Road
Carnegie, PA 15106
412-498-4317
You don't want a '67 k-member unless you want to cut the idler arm mount off to add the correct 68-up piece to it.
