67-69 gas pedal
dane1968
Active Member
El Paso,Texas
Will a 67-69 gas pedal fit a '63 A-body Dart? Need to know, because, I want to convert to a Buchillon kickdown and throttle kit for a Super Six conversion.
I don't see why it wouldn't. Drill two holes in the proper location on the firewall and you should be fine.
Yep, done all the time.. In 64 V8 cars came with the cable pedal.I think Slant 6 A/C cars too. You can also use the early B body pedal and cable buy drilling the floor mount and drilling the fire wall to attach the cable bracket. The easiest to get is the 67-up hanger pedal assembly. Works the best too. I installed the B body set up in my 64. will be replacing it soon with the 67 style.
Do it right and get an Early A (63-66) V8 gas pedal.
The dimples for the holes are in the floor. Do a search on the site for one.
