Mar 24, 2015 #1 mikebee now's the new later... Joined Feb 23, 2011 Messages 1,972 Reaction score 132 Location n.c. Rating - 100% 27 0 0 Contact seller 100$ & shp from NC 28001 postal money order only! thanks! Attachments image.jpg image.jpg 64.8 KB · Views: 334
Mar 24, 2015 #2 tekslk Well-Known Member Joined Dec 13, 2009 Messages 3,140 Reaction score 97 Location McClure, Pa Rating - 100% 2 0 0 Are they 340 or 360 I thought they were two different animals?
Mar 24, 2015 #3 greymouser7 Vagrant Vagabond “Veni Vidi Vici” Joined Apr 17, 2010 Messages 3,748 Reaction score 1,478 Location 78002 down the road from Atascosa, Texas Rating - 100% 20 0 0 Yeah I need to know that to, I'm beginning to mix it up. Is it 273/318/340 engine mounts & 360 is different right?
Mar 24, 2015 #4 R rick hughes 71dusterdude Joined Jan 21, 2009 Messages 209 Reaction score 5 Location wv Rating - 66.7% 2 1 0 340 & 360 are the same
Mar 24, 2015 #5 mikebee now's the new later... Joined Feb 23, 2011 Messages 1,972 Reaction score 132 Location n.c. Rating - 100% 27 0 0 what he said....360 and 340 are the same
Mar 25, 2015 #6 Dustem Active Member Joined Feb 4, 2009 Messages 29 Reaction score 0 Rating - 0% 0 0 0 318 uses different drivers side mount.
Mar 25, 2015 #7 mikebee now's the new later... Joined Feb 23, 2011 Messages 1,972 Reaction score 132 Location n.c. Rating - 100% 27 0 0 273 and 318 use a different driver side mount than 340 and 360... They all use the same pass.side.
Apr 1, 2015 #8 mikebee now's the new later... Joined Feb 23, 2011 Messages 1,972 Reaction score 132 Location n.c. Rating - 100% 27 0 0 i have all the fine thread bolts an nuts for these too.
Apr 13, 2015 #9 keggy1969 Well-Known Member Joined Oct 27, 2011 Messages 217 Reaction score 27 Location hagersville Rating - 83.3% 5 1 0 i think the left side is 3/8 narrower than the right side
Apr 14, 2015 #10 mikebee now's the new later... Joined Feb 23, 2011 Messages 1,972 Reaction score 132 Location n.c. Rating - 100% 27 0 0 keggy1969 said: i think the left side is 3/8 narrower than the right side Click to expand... this should show the difference....top pic is a 340 mount on a 340... bottom pic is a 273/318 mount. Attachments IMG_1936.jpg IMG_1936.jpg 63.7 KB · Views: 144 IMG_1923.jpg IMG_1923.jpg 52.3 KB · Views: 157
Apr 14, 2015 #11 ir3333 Well-Known Member Joined Jun 1, 2008 Messages 6,106 Reaction score 1,900 Location ontario,canada Rating - 100% 2 0 0 Miike is correct.You should weld on the third ear if using a 318 drivers' side mount on a 340 or 360 and a 1/4" spacer as well.
Apr 15, 2015 #12 mikebee now's the new later... Joined Feb 23, 2011 Messages 1,972 Reaction score 132 Location n.c. Rating - 100% 27 0 0 fo sold!
