500duster
I'm finishing up a project and selling some spare parts. Most engine parts came from the engine that was in the car when i bought it. This engine supposedly had break in time on it only. ITEM 1 MOPAR 292 .508 lift cam and lifters. i marked and boxed lifters as to which lobe they were on $75 OBO. ITEM 2 set of 8 speed pro .060 over flat top 4 valve relief pistons with rods, about 10:1 compression with stock heads $100 OBO. ITEM 3 CAL Custom cast aluminum valve covers $40 OBO. ITEM 4 aftermarket damper internal balance (degreed from 30 btdc to 10 after tdc) $40 obo.ITEM 5 water pumps 1 passenger side inlet$10 1 drivers side inlet $15. Item 6 small bolt to large bolt pattern wheel adapters $40 obo. ITEM 7 is complete 10" front drum brake set up with A arms, spindles ,drums, backing plates, shoes and hardware $100 OBO. ITEM 8 is 73 up large ball joint A arms $40 obo. ITEM 8 Edelbrock performer rpm intake $125 obo. ITEM 9 is a single wire alternator from my drag car, (I went with mini alternator) $40 obo. Item 10 is a set of 8 stock 340 pistons and rods with new rings on pistons. I believe rods were resized but can't remember for sure as I have had them stored for years $80 obo. ITEM 11 set of 8 TRW domed 12.5 to 1 std bore 383 pistons with rods, pistons good rods need glass beaded and at least checked $50. ITEM 12 is 2 sets non adjustable rockers with shafts and push rods ( 1 set has no hold downs, other set has 15 comp cams push rods with 1 that looks stock) $75 for both sets or $40 apiece obo. ITEM 13 2 new front drum brake hoses ( I converted the car to discs) $10 for the pair. ITEM 14 2 new upper and 2 new lower ball joints from Just Suspension, these are the small ball joints brand new with hardware $100 obo. Last item is a new set of Monroe Sensa Trac load adjusting shocks new in box $45. All prices plus shipping. I will take paypal or money orders. I could not post all pics, I can send pics of alternator, rockers and shafts, brake hoses , A arms, damper and 383 pistons on request. Thanks.
