67 Dart Remote Mirror Demystified
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Bought a mirror to see if it would be possible to modify it to be a remote right hand mirror. Probably not!
Mirror, (glass removed)
Disassembled
Back of mirror holder (note the colors)
Cables pass thru the trim
Cables pass thru the mount (there is a plastic tube around the cables, don't know the reason)
Screw that holds the mirror trim to the mount and holds the mirror actuator (part the glass mirror is glued to) into the mirror trim
Stud and nut that attach the assy to the door
Screw that holds the front of the mirror to the door
Interior joystick
Cont....
Part 2...
Spring metal retainer to align the joystick
Retainer trim nut
When reassembling the mirror, note the alignment tabs in the mirror head
While holding the mirror actuator, mirror trim and mirror mount install the screw
Install the stud ( this one has a buggered thread near the machined end I don't know if it is intentional, the stud seems to be hardened as I could not file it down, or my HF files were crappy)
The spring retainer goes on one way, and keys the joystick so moving the stick up makes the mirror tip up
Trim ring / nut (note joystick is in the up position)
Mirror in the full up position
Part 3...
Some notes...
The actuator where the glass attaches to has 3 holes that the cables go thru. There is a cable crimp on each one. This mirror had one if the crimps that pulled thru the aluminum mirror glass mount. I was able to get it back thru. You could probably make a small horse shoe clip to put under the crimp to prevent the crimp from pulling thru.
The scratched areas are where there was 4 small dollops of glass adhesive.
A question about a mirror not being tight is probably the crimps no longer being tight to the aluminum mirror holder
There is a spring in the joystick which if it was too loose it too might not allow the mirror to stay in position
I noticed that when the cables are laid out straight, the actuator head was excessively loose, curving the cables caused it to tighten up nicely.
The last thing I noticed was the actuator head had "R" "Y" "G" stamped on it, this corelated with the cable colors.
Part 3...
Some notes...
There is a spring in the joystick which if it was too loose it too might not allow the mirror to stay in positionView attachment 1715524582
I tore one apart and put it back together and sold it , couldnt find any longer cables to use in it that I could rig. , and didnt want to spend a lot of time on it back when building my car , had too much to do .
The right mirror from a right hand drive car is remote, but with a similar short cable and shallow bowl. To have the correct deep bowl right hand mirror casting for left hand drive car along with long cable assembly requires parts from 3 mirrors. My cable assembly came from a 87 Gran Fury. The controller is in a second ignition switch bezel beside my ignition switch.
Part 3...
Some notes...
My mirror joystick was bent and there was a gap between the mushroom head on top of the spring and the bottom of the joy stick. Mirror wiggled and fell down after adjusting. You can’t take it apart without destroying it, but you can twist the screw-like cables clockwise to lower and tighten. This lessened the gap, but not enough to create friction. I added a twist tie to stretch the wires (inside door) and place friction on the wires. Seems to work, will see how long it lasts. Bent the joystick straight by hand.
First car I had with a remote was my '70 RR. I thought that was IT back then. No fancy electrics, no gears and motors, just some cables. Of course they can rust LOL
