[Found!] 67 Dart Trunk Lock and Hardware
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Hi all
I'm looking for a 67 Dart trunk lock and associated hardware.
I know I can buy reproductions
Here is the rub...
As I understand it.
67 had a unique key way
68 had a different unique keyway
And 69 up had another unique keyway.
There was a Chrysler memo that said if a lock was replaced under warrantee all locks would be replaced with the 69 up style keyway
So I'm looking for a 67 style keyway trunk lock.
This is an "I" key.
Let me know what you have.
It should be presentable and not corroded/rusted
Light scratching on the stainless outer cover is ok
If you think you have what I need I can send you a key to test.
Thanks
Dana
Thanks.
I'm trying to maintain my glove box door lock and have only one key for trunk and glove box.
The lock MIGHT have a part number on it of 2802 404
Not sure if it might indicate the correct 67 keyway.
I have one trunk lock with hardware, but no key as well as some extra hardware. I don't see any part numbers on it so there is no way of knowing the production year. Do you have the original trunk lock? I have done it several times and have extra tumblers and springs.
I could send you a key to see if it is the correct key way?
What are you wanting for the lock?
I do not have the original trunk lock it was mia like 1/2 the rest of the car!
