mike1965
1967 Dart has a 440ci in it rite now and has run 10.90 with 26x8.5 hosier quick time tires and 4.30 gears.
Earlier this summer the car went to the chassis shop to have the springs moved inboard and frame connectors and I installed an alum. rad and elec. fan
Its in the shop now getting the 514ci turbo stroker motor and floor shifter 88mm turbo and blow thru setup and the front part of the cage installed I will post pix as the work gets done
Here are some pix of BLACK BETTY the car before the mini tub and after
Thanks Mike
Thanks Mike
