[WANTED] 67 glove box handle
4spdragtop
Ontario Parts Unknown
Well, looks like I learned there is differences in 67 barracuda glove box doors. Difference is in the mount hole opening between the standard handle and the "upgrade" lock/handle. I didnt realize the difference and now have a glove box designed for standard handle....:BangHead:
So to rectify I either need a standard handle OR a glovebox door designed for upgrade handle(that I have).
Dammit all, anyone got a nice glove box door or a nice standard handle?
Thanks
Steve
Steve, is the opening on the inside of the door stamped differently?
Post some photos.
The opening in the door for a “standard” pull handle is a screw hole with a second hole that locates the handle via a small pin cast in the pull handle . The door for a locking latch has a hole big enough for the cylinder to pass through.
Yep, different....I just figured it out now...I already sold the other(orig) door as it had a few pits.
Post some photos.
I was trying to see if you could just drill a hole, guess not.
Are the dart and Barracuda doors the same?
too bad I have a 67 Dart door i could part with if you needed one in the short term
