carfreak6970
So I have been slowly chipping away at this. I was able to get the bellhousing alignment done, new piolet bearing installed, clutch and pressure plate installed. I ended up needing another input shaft and bearing retainer since mine were very pitting. Disassembly of the transmission went fine, assembly was a pain. Always had an issue with mating the main shaft up with the input shaft while keeping the 3-4 collar and syncro from falling apart. But I got it together with new seals!
installed the trans onto the engine and reversed the process of getting it into the car
cleaned up the engine bay a bit while the engine was out and it is looking pretty good in there!
now it is just putting the parts I took off back in it. Only things I am waiting on is the trans fluid but I have everything else to getting it back to road worthy! have an unsupervised long weekend ahead so I hope to get a lot of that stuff done.
