sireland67
I would be tempted to hit the buy it now button for that price, but check which fitting you have on the carb. I don't have a carter or eldebrock here to tell you what thread size.
I know they exist, had one on the carter competion series on the old 318 that was originally in my duster, just not sure of what thread the carb is.
But I do remember buying the fitting from summit.
Maybe give them a call?
You can dissemble and clean mag lifters.
There is a snap ring that holds the plunger in.
Actually they are easy to take apart.
Soak in mineral spirits overnight, clean and re-assembl.
You will not believe the garbage that comes out of them, for some reason they are the "trash collector of the engine".
Don't run it ticking, you will tear up pushrods and rocker arms.
Maybe so, but it makes more sense - timewise - to simply install a new set.
I can always fiddle about with the old ones another time.
-Kurt
Be prepared for sticker shock on a new set.
$89 from RockAuto (Engine Quest), $184 from Advance (Sealed Power).
I can hack the RockAuto price.
-Kurt
You actually have me confused on no oil to the drivers side.
Mags oil thru the push rods to the rockers.
The lifters have to be defective.
Spun cam bearing would loose oil pressure to the whole engine, and the passenger side would have no oil also.
Here is a pic of a new roller for a mag, I assume yours look like these?
The lifters that were in the engine when you bought it, and the new ones have no oil to the rockers correct?
What did the lobes on the cam look like?
I think you may be correct on a plugged gallery unless somebody can provide another explanation.
That motor looked clean, so I really do not suspect sludge, was there any gasket made with RTV when you tore it apart?
RTV is good and bad depending on how it was applied.
