[WANTED] 68 383 gts kickdown linkage
The down rod, tranny pivot and the rest to the trans throttle arm are the same. You have the important part. Only What you show ^^^^^^^^^^ above is installed upside down!
See post #6, It is a 440 or appears to be. But the linkage is the same!
The down rod is not the same as 440. 440 is longer different shape too I believe
