[SOLD] '68 383 Longblock
HELLRAZR
Ohio
1968 383 long block. Rebuilt at the machine shop a handful of years ago then plans changed. Never fired, or fully assembled. Never even finished painting or removed from the stand. Forged crank, new bearings etc. Keith Black pistons & rings, Mopar Performance cam, lifters & springs, 452 heads redone, double roller timing assembly, Melling oil pick up, 933 pan, oem oil pump & valve covers. As you can see it will need to be cleaned as the dust has collected heavily while sitting in the shop but that’s it. You’ll obviously need to add your own head bolts, accessories & gaskets etc. to make a complete engine as this is just a long block. Will add more pics later. $2500 and you can have the stand it’s bolted to. Thank you for looking. Located in 26101
